OK, there’s obviously enough cooks in this kitchen! I’m getting out!
We will miss your special sauce.
Thank you all very much. I found an error for the temperature sensor. I wrote Ld instead of Id.
I rechecked the humidity sensor. There are still problems with it. In variables, the value is present, but is not displayed
Maybe that is not so prescribed, please take a look
on TermGigr#Humidity do
SendToHTTP 192.168.100.4,3480,/data_request?id=variableset&DeviceNum=65&serviceId=urn:micasaverde-com:serviceId:HumiditySensor:1&Variable=CurrentLevel&Value=[TermGigr#Humidity]
endon
Now everything is working. ESP sensors are very cheap. If you need information on how to make them and ask for them again, please contact me and I will help you.
I’ll bite. What are you using for a board? Does it have built in wireless/network or are you using an external radio module? I have a lot of experience with MySensors but always interested in a new method.
Good afternoon. Tell me what I can do to display the online ESP status.Like a plugin “HTTP Switch (WiFi Switch)”
This is necessary for the ESP8266 Board where the temperature sensors are located
Sorry to drag this up, I’ve made a tasmota rule following the above guidance.
I’m using an SI7021 sensor and have come up with the below rule:
Rule3 on Tele-SI7021#Temperature do WebSend [192.168.0.24:3480] /data_request?id=variableset&DeviceNum=68&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=[SI7021#Temperature] endon
but the result I get form this in the Vera CurrentTemperature is [SI7021#Temperature]
Does anyone know the right variable for this?
I do not have any SI17021 sensor, but I use rules from a few Tasmota sensors with DH22 (AM2301). The rule I use is the following:
Rule1 ON tele-AM2301#Temperature DO Var1 %value% ENDON ON tele-AM2301#Temperature DO WebSend [VERA_IP:3480]/data_request?id=lu_action&DeviceNum=173&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=%Var1% ENDON
I can see a difference in the data request part compared to yours. Hopefully my sample can be of use so that you can get it right.
//ArcherS
Perfect! Thanks.
Needed that variable!
Nice to hear that it worked!
//ArcherS
