The Philio PSM02 4-in-1 Z-Wave Sensor not reporting
Hi the standard set up for this device doesn’t seem to work, i get no reports from the device. I have had a look at the forums and made some adjustments to the parameters but I’m getting nowhere.
Has anyone successfully got this set up with a vera plus ui7?
If so how?!
Same issue here, the device seems not to work at all. Not motion, door opening, lux and temperature is being reported only if I poll the device manually and wake it up manually also.
I have tried with another controller and it works flawless.
Lets hope some1 has it configured at ui7 and could share settings/parametres
I had Customer Care to look into it, and the solution was to configure the byte 7 with the value 54
So far it’s working great now :slight_smile:
