THE BUTTON FIBARO FGPB101
I have some buttons FGPB 101, and an RGB light bulb and a vera edge controller.
I created a custom scene : when one button are pressed color of RGB light bulb will change to Red (for example) and when press second button color will be changed in Green.
When I try to press the second button, the color of RGB light bulb not changed, I need to press again and some times again again to see the changes from Red to Green.
I think it’s a delay from vera controller and button and rgb light bulb.
Any solution to remove this delay or to improve the speed?
Thank you :slight_smile:
Have you had any luck with this issue? In my case, I have the Vera Plus and it only recognizes one tap on the button no matter how many taps I use… It always triggers the one tap scene…
