I have a new Vera 3 running U15. Automator is in contact with Vera.
I have gotten the notification plugin installed but, when I try to enter a device identifier it doesn’t stick. The next time I look at settings, it says “current devices: undefined.”
[quote=“screaminbob, post:1, topic:170595”]I have a new Vera 3 running U15. Automator is in contact with Vera.
Any ideas would be appreciated.[/quote]
If you haven’t done so already you should update the plugin files to the UI5 version. You can do this directly within the app by clicking the “Update” button. I didn’t have time to implement an automatic check. See attached screenshot
This is what I have done.
After the installation of the plugin created device.
from the iPhone app updated the plugin
Entering of the device ID did not work
Removed the device from the vera.
recreated the device via the iPhone.
Entering the device ID…“Set” button is having any effect.
You appear to be installing the UI4 version of the plugin. Using the Update button in the screen shot earlier in this thread should install the UI5 version (the Plugin Version should show UI5.6, not 3).
[quote=“TANE, post:10, topic:170595”]I’m using the phone for the update.
iPhone is installing v3.
Just done a new update and getting the next error. [/quote]
Are you sure you have the latest update of Automator.app? Version 3 is VERY old.
I’ve attached the plugin files that you can upload directly to the vera.
The easiest way is to send a notification using the “advanced” option in a scene. That scene can be triggered by an event that you care about.
If you are familiar with Lua then you can send push notifications directly from script, which opens up much more options. It does require technical skills though.
