TEXECOM Premier Elite Plugin
Doubt it would be vera problem, I know texecom have been having some issues with their servers lately which have apparently now been fixed…
The connect version is currently on hold at the moment as a more pressing project has arisen and I’ve lost my firmware flasher and the connect protocol is lacking a fairly major command used for the setup procedure… There is a work around but it’s quite clunky and unsatisfactory… I’ve asked texecom for it to be added (it was in the simple protocol!) but I’m not exactly holding my breath…
In the mean time the plugin should theoretically be compatible with a smart com as it connects via internal ip.
Failing that if your vera is near your panel you could connect to a spare com port on the panel via USB cable (texecom cable is about ?30-40 but apparently you can use any standard USB to serial cable… I’ll look up the link for you
[url=https://cybergibbons.com/alarms-2/programming-a-texecom-premier-elite-12-w-using-a-ftdi-cable/]
https://cybergibbons.com/alarms-2/programming-a-texecom-premier-elite-12-w-using-a-ftdi-cable/[/url]
Hope this helps, Sam
