Catman
July 25, 2019, 7:18pm
1
Failure on two of the temperature sensors attached to my Fibaro
07/25/19 17:23:27.101 ZWaveNode::HandlePollUpdate node 35 device 114 skipping bogus class 0x31 <0x765c4520>
The other two work fine.
Removal / inclusion would be nice to avoid…
Thoughts?
Cheers
C
HSD99
July 25, 2019, 7:20pm
2
Try pulling the battery, wait a minute or two, and reinstall. No guarantees, but it might save you from exclude/including.
Catman
July 25, 2019, 7:23pm
3
No batteries chap. FGBS231. I could unplug it, but that’s never worked before…
Cheers
C
HSD99
July 25, 2019, 7:24pm
4
Oops! I had this problem with a Fibaro door/window sensor and the battery trick worked. You could try a reconfiguration.
Catman
July 25, 2019, 7:28pm
5
How so?
What would you suggest?
Cheers
C
HSD99
July 25, 2019, 7:40pm
6
Advanced–>Commands—> Configure node right now. This will redo the configuration without exclusion/reinclusion. I’ve had this fix problems on various devices. YMMV.
Catman
July 25, 2019, 7:55pm
7
Ta
Thought that’s what you meant.
‘No commands are available’ on the temperatures sensors. I’m a little loathe to do it on the Fibaro itself as two are still working…
C
HSD99
July 25, 2019, 8:16pm
8
As far as I know, commands are only available for parent devices. The reconfigure may fix the child problem.
Catman
July 25, 2019, 8:18pm
9
Hmm
And against my better judgement I executed that against the multi channel sensor
Now sitting there:
Please wait! Getting Multi Channel info
Logs:
02
07/25/19 21:17:44.100
UserData::AlarmCallback ALARM_RESYNC_DEVICES <0x763c4520>
02
07/25/19 21:17:44.103
RAServerSync::SyncDevice can’t sync 116 without json <0x763c4520>
02
07/25/19 21:17:44.104
RAServerSync::SyncDevice can’t sync 115 without json <0x763c4520>
02
RAServerSync::SyncDevice can’t sync 114 without json <0x763c4520>
02
07/25/19 21:17:44.107
RAServerSync::SyncDevice can’t sync 111 without json <0x763c4520>
02
RAServerSync::SyncDevice can’t sync 112 without json <0x763c4520>
02
07/25/19 21:17:44.108
RAServerSync::SyncDevice can’t sync 113 without json <0x763c4520>
02
07/25/19 21:17:45.637
RAServerSync::SyncDevice alt 0 response 200 url https://vera-us-oem-device11.mios.com/device/device/device/50103066/localdevices with 23299 bytes <0x763c4520>
01
07/25/19 21:17:48.505
ZWaveNode::HandlePollUpdate_Multi_Channel_Cmd node 35 cannot find embedded 3/3 <0x765c4520>
01
07/25/19 21:17:49.837
ZWaveNode::HandlePollUpdate_Multi_Channel_Cmd node 35 cannot find embedded 4/4 <0x765c4520>
01
07/25/19 21:17:51.145
ZWaveNode::HandlePollUpdate_Multi_Channel_Cmd node 35 cannot find embedded 5/5 <0x765c4520>
01
07/25/19 21:17:52.485
ZWaveNode::HandlePollUpdate_Multi_Channel_Cmd node 35 cannot find embedded 6/6 <0x765c4520>
C
