Temp Sensor Recommendation Please
I need a simple room temp sensor. No thermostat. Would prefer something ac powered and not battery. Other stuff (humidity, etc.) OK but not mandatory.
Aeon multisensor? FortrezZ? It’s easy to find lots of good help here, but harder to find recommendations, why I’m askin’.
Thanks, Bob
I’ve personally used a Twine with the plugin I did up for temperature. The unit itself is expensive though, so it may not be the best thing out there.
The Everspring temperature and humidity sensor works really well. I have one in the basement and one in the attic. I think its measurements are slightly off but for my purposes it’s more than adequate.
I use the Fortrezz units but they’re subject to anomalies such as those discussed in this thread, “FortrezZ WWA-02 leak false positive”, in this forum.
I use a RFXtrx433 and sensors Telldus Termometer och hygrometer för Tellstick - Smarta temperatursensorer | Kjell.com
Available in Sweden. They are battery powered but with great range, have one in my garage 30 m from my house that works fine.
I get temp readings from the thermostats, HSM100’s (V3), Aeotecs, Eversprings and a single Fortrezz.
Thermostats are on C-wire, some HSM100 on an AC adapter. Aeotecs can be USB powered, but I have them on battery. Everspring on batteries. Fortrezz on batteries.
The Eversprings have a display and can auto-push measurements to Vera based on delta. We use these in the bedrooms.
The Aeotec can auto-push periodically.
The Fortrezz used to be a relatively inexpensive way to get a temp sensor, but the other units have come down in price (or weren’t available, or fully compatible in the past).
