Tasker not talking to Autovera but Autovera talks to Tasker
Ive posted this in the Autovera Forum but Im crossposting this here in case anyone can help.
Up until last week Ive had no issues with Tasker and AV - however last week my profiles and tasks got wiped out from another tasker plugin and I had no backup so I was forced to recreate (also forced some housekeeping in tasker).
When I recreated a few of my tasks Ive found that Tasker wont talk to Autovera for even the simplest of tasks like turn on a light - however I can go to that device directly in AV and toggle that device successfully.
Weird thing is that autovera WILL update tasker any status changes (profile)
The task:
Tasks - Plugin - autovera - devices - Light -
Action:State
State:Turn On
Service:power Switch
When I run the “turn on light” task, tasker sits there for about 30s and then returns:
10.46.24/ActionArgBundle key: DeviceName: replace String value with null
10.46.24/ActionArgBundle key: DeviceId: replace String value with null
10.46.24/ActionArgBundle AutoVera Devices: DeviceName: ignored replacement specified for null value
10.46.24/ActionArgBundle AutoVera Devices: DeviceId: ignored replacement specified for null value
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:newLoadlevelTarget
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:newArmedValue
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:NewMode
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:NewModeTarget
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:EnergyModeTarget
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:NewFanSpeedTarget
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:NewDirectionTarget
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:NewApplication
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:NewCurrentSetpoint__heat
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:NewCurrentSetpoint__cool
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:NewAutomaticWhiteBalance
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:NewFixedWhiteBalance
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:NewRotation
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:NewBrightness
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:NewColorSaturation
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:presetNumber
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:Id
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:Name
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:newText1Value
10.46.24/ActionArgBundle AutoVera Devices: extra key not found in bundle:newText2Value
10.46.24/E FIRE PLUGIN: AutoVera Devices / com.twofortyfouram.locale.intent.action.FIRE_SETTING: 12 bundle keys
10.46.24/E AutoVera Devices: plugin comp: com.joaomgcd.autovera/com.joaomgcd.autovera.broadcastreceiver.BroadcastReceiverFire
10.46.24/E add wait type Plugin1 time 30
10.46.24/E add wait type Plugin1 done
10.46.24/E add wait task
10.46.54/E Error: null
Any help would be appreciated.
I see that you are using State. Have you tried event?
I’m having this problem… exactly. Was there ever a solution?
Well I figured it out, with a new update to Android with power save mode on somehow disables tasker. Least this worked for me.
I’ve been getting this a lot recently.
A reliable solution is to remove AV and reinstall it.
Also sorts out authentication issues.
After the most recent Samsung update, again Tasker wasn’t working. What I did was refresh my devices and auto Vera and it also refreshes the scenes at the same time. That works for me this time.
