Hi
I just install and testing out the rfxtrx plugin with lightwave rf switches. Its working fine except the on/off state is not synchronize
Does the plugin support sync state - pressing button on the actual switches update the device on/off button ?
Check that you are not using RFXtrx firmware v66.
im using firmware 71. Any other settings i should be looking at.
thanks
This may be the reason why it doesn’t support state send to vera
I’m using lightwaverf switch and according to this site it doesn’t have a transmitter
http://www.megamanuk.com/lightwaverf/products/power-control/jsjslw270ss/
