Hi all!
Purchased a Veralite this week and though I’m new to home automation, implementation has been quicker than I expected. ![]()
Instead of zwave-based light switches, I decided to use Insteon Switchlinc and a Powerlinc modem. So far, I’ve been able to successfully include every switch and control them from the dashboard.
To include a switch, it seems the only way for the controller to see it is if I pair it with the modem, then add it as a Device. Is this the correct way? I also have an IOlinc, but all I seemed to have to do was plug it in and add the device altid. Which is correct?
After successfully(?) including the switches, I’ve tried to set up scenes where one switch triggers the other switches to turn on. I can create the scene, validate each device and run it from the dashboard, but if I try to activate the switch locally, the other switches never turn on. I can set up the switches directly with each other using their internal Insteon controller/responder, but obviously, this isn’t ideal. Is there a device I’m missing or is this a limitation of the Veralite?
There are three lights involved, all outside, with what I call the “controller” light switch outside my kitchen entrance… Ideally, I’d like to create the following scenes:
Scene one:
IF controller light is “off”,
AND controller switch is toggled “on”,
THEN POWER-UP controller light.
Scene two:
IF controller light is “on”,
THEN POWER-UP responder lights.
Powering off controller switch would always power-down responder lights.
Hope that makes sense. Any input is appreciated!
