Dear forum users,
I’m relatively new to the whole MiCasaVerde scene but I’ve recently purchased a Vera Lite. I’m still learning quite a bit about how to configure, script and tweak my Vera Lite. I’ve run into a small issue which I cannot resolve somehow…
I’ve got a Fibaro FGS-211 in wall switch in my bedroom. The switch is not physically connected to any device but I use it to switch two plug-in dimmers that are on opposite sides of the bed. So far so good - I can switch the lights on and off and even dim them with my pulse switch that is connected to the Fibaro unit in the wall… I configured the plug-in dimmers as associated devices in group ‘1’ on the Fibaro unit.
The problem that I’m having is that whenever I switch the Fibaro ‘on’ using the Vera web interface (UI5) it sends the appropriate ‘on’ commands to the associated dimmers - however, when I switch the Fibaro switch ‘off’ using the web interface it does not send any commands to the related dimmers (so they remain on…)
How can I fix this?
Many thanks for your help!
