Weird thing-one of my Intermatic wall dimmers now shows a current temp below the dimmer-slider in the devices tab. It says “current temperature=70” Is this a bug of some sort? None of my other switches report temperature!
Is the switch a HA14WD model?
See:
http://forum.micasaverde.com/index.php?topic=1906.msg6941#msg6941
jduel, can you go to advanced, tech support and submit a trouble ticket? Then we’ll check the logs to see how this happened. It sounds like a software bug we need to fix.
Just checked-it’s an HA06C. Thanks!
so I guess the switch will only turn on what a certain temp is reached…
