Vera won’t automatically remove the device. After you have permanently disconnected the device, click the device’s wrench icon and then click the trash can icon.
If the device later re-appears in the Vera UI and you can;t seem to eliminate it, you may need to run the following URL in your browser.
http://<local_Vera_IP>:3480/data_request?id=device&action=delete&device=<device_ID>
[quote=“Z-Waver, post:2, topic:176882”]Vera won’t automatically remove the device. After you have permanently disconnected the device, click the device’s wrench icon and then click the trash can icon.
http://<local_Vera_IP>:3480/data_request?id=device&action=delete&device=<device_ID>[/quote]
Seems like I’ve got it removed. After I deleted it, an appliance controller appeared that had also been added at one time but deleted. Hot sure why it reappeared. Deleted it successfully too.
Thanks for the info.
