Switch LED status on Leviton controllers?
Searched all over and can’t find if you can do this. I like how you can switch the LED status on the GE switches… I’d like to do the same on the Leviton controller, so the LEDs are on when the scene is off. E.g., I can see the controller in a dark room.
Any way to do this?
I think in Leviton’s philosophy the LED is on when the scene is active, so there may not be another way (natively). Perhaps something can be done by forcing the On and Off scenes to be controlled by Vera, but I haven’t tried this. You’ll have to weigh getting the LED behavior you want versus the directly controlled scene capability of the Leviton gear.[/quote]
I figured… thanks.
Probably cheaper to install a night light nearby! :smiley:
