@shallowearth, thank you. All this has of course been tried. The devices dont even do it 1 meter apart, same behaviour as 6 meters (other end of room, same room). Some associations are not even removed after exclusion. You must also reset the device itself. To say: been there, done that. And a lot more… none helps.
Edit: some quotes from Vera support… October, November 2018. See the pattern?
Associations go directly from Device to Device, basically as long as the devices involved support that type of association Vera will be able to set it.
If somehow it fails, you should check with the manufacturer of those devices directly as they should know exactly why that association cannot be set or how it should be set between their devices.
Associations skip Vera as they happen at a device to device level.
Let us know if you have any questions and we will get back to you asap.
The issue could be caused by that active bug, even though the Association should be Device – Device, activating Device 1 from/through Vera could cause a chain delay.
We pushed this to our development team, currently we do not have any real ETA, but this should get fixed in one of the upcoming releases.
Thank you. Have a good day!
We currently cannot make any promises related to this Device, device integration is handled by our Project Managers based on the actual priority list. Our team is looking to improve the overall performance and stability of our services/products alongside with device integration and other fixes.
That’s why we do not have an exact date or estimated date for now.
We are focusing on adding as many devices as possible in the list of ‘full supported devices’ and the Fibaro products are definitely in our development roadmap. However, this will require time and development efforts. But please rest assured that we are doing our best to move the things around in accomplishing this objective.
Our product management team is well aware of your feedback and please allow us a little more time to deliver this.
Apologizes for the delay!
When it comes to those Fibaro Models it’s very hard to manage it properly due to the device’s nature as well. We can attempt to fix this by changing the current settings of the device into something different, however, we cannot guarantee that this will work as expected.
Our team is working on all integrations step by step, depending on each device and each situation the process could be short of long, even if it seems as an excuse, it’s actually very hard to integrate a device based on all the requirements from each involved part.
Please Enable Tech Support on your controller and provide us with the Generated String. Let us know if we can test the network and and also let us know if we can test any of the Fibaro devices that you have (FGS223).
Thank you. I’m waiting for your reply!
