This is a list of harmony Hub products that have been reported to work with this plug in. It will work for Hubs with or without a Harmony Remote.
- Harmony Hub
- Harmony Ultimate Hub
- Harmony Smart Hub
This are some of the (older) hub products that are not working with this plugin.
- Link Hub
Note: the Harmony Hub Extender is a Z-Wave extension for the Hub and has no link to this plug-in.
Note: the plug-in can only control IR based devices. Any device that communicated with the Hub via IP, for example Phillips Hue, cannot be controlled via this plugin. IP based devices should be controlled from your Vera directly using the appropriate plug-in.
