I’m historically an Innovus customer, but i’m concerned by the ‘no response’ from them since january. i’m not sure, but they seems to be dead or something.
So, and because the technology is pretty new, I’m considering migrating from innovus router to the vera one. But i can not change all the devices, so my question : does vera supports (or plans to support) the legacy innovus devices like RaOne Smartpower (http://www.innovus.eu/index.php?id=73), RaOne Smartdimmer (http://www.innovus.eu/index.php?id=72) and the smooth remote (http://www.innovus.eu/index.php?id=76) ? I’ve also other product, but they are not directly from innovus like the EZmotion sensor wich seems to be ok (i’ve seen the other thread about it) and the T° sensor from LS Control which I don’t know.
Thanks for the answer.
I’ve bought the innovus powerswitches mainly for the ‘meter’ functionnality, but I suppose It not so difficult to add the functionnality.
First I’ll really check if they are dead and let you know,
Tom.
In the US I can’t get my hands on any devices that support the meter class. If the Innovus does, I’d like to add support for it remotely, if you don’t mind. Would you be able to ping us on the tech support chat and open the back door? I can remotely add support for the meter and we can make it work in probably less than a week, if you don’t mind letting us poke around remotely on your box.
We did add now that you have to check ‘Let Vera manage associations’ before Vera will override your associations (then save, then reconfigure node). That’s because some users already setup associations manually with another controller and didn’t like us automatically overwriting them.
mhn, I’m following the Zwave Add controller Wiki and everything is looking good. My z-ring is configured, showing the green wheel. I have added the “scene button is pressed”-event to a scene.
But, as you all guess, nothing happens when a press any of the buttons on the z-ring. Even a desperate double press didn’t do it.
What I haven’t tried is to change the Custom Z-wave settings for the z-ring device. What are your setting here? How did you figure them out?
In the end, when everything is working, does button 1 correspond to “key 1” and so on?
