Hello !
I’ve found a very good deal at Costo"s for the Nanoleaf (9) pack, bought it, installed it, and succefully working with Alexa.
Is there a way to control the Nanoleaf trough the Vera ?
Hello !
Their website is not very helpful so it is not clear how they communicate. It speaks of an API so one may be able to write a plug-in for Vera if Vera can see it. It also talks of HomeKit so again it appears to be possible to have them controlled by Vera.
Apparently there is an open API.
I’m using lua code, i hope it helps until someone will write a plugin:
On/off aurora
[code]local http=require(“socket.http”)
local auroraToken = “YOUR_TOKEN”;
local siteurl = “http://AURORA_IP:16021/api/v1/”…auroraToken…“/state/on/”
local siteurl1 = “http://AURORA_IP:16021/api/v1/”…auroraToken…“/state/”
local respback = { }
local res, code, response_headers, status = http.request
url = siteurl,
method = “GET”,
headers =
[“Content-Type”] = “application/json”
sink = ltn12.sink.table(respback)
if tonumber(code) == 200
then
for key,value in pairs(respback) do
auroraOn = string.match(value, “%a+”, 8)
if auroraOn == ‘false’
then auroraOn = ‘true’
else
auroraOn = ‘false’
local payload = ‘{“on” : {“value”:’…auroraOn…‘}}’
print(payload)
url = siteurl1,
method = “PUT”,
headers =
[“Content-Type”] = “application/json”,
[“Content-Length”] = payload:len()
source = ltn12.source.string(payload),
}[/code]
Next effect
local json = require(“dkjson”)
local siteurl = “http://AURORA_IP:16021/api/v1/”…auroraToken…“/effects/effectsList”
local siteurl1 = “http://AURORA_IP:16021/api/v1/”…auroraToken…“/effects/select”
local siteurl2 = “http://AURORA_IP:16021/api/v1/”…auroraToken…“/effects”
– current_effect
url = siteurl1,
method = “GET”,
headers =
for k, v in pairs(respback) do
auroraCurrentEffect = v
auroraCurrentEffect = string.gsub(auroraCurrentEffect,‘"’,‘’)
break
– all effects list
url = siteurl,
method = “GET”,
headers =
function get_key_for_value(t,value)
for k,v in pairs(t) do
if v == value then return k
function get_value_for_key(t,key)
if k == key then return v
for k,v in pairs(respback) do
auroraEffectsList = json.decode(v)
auroraEffectsSum = #auroraEffectsList
auroraCurrentId = get_key_for_value(auroraEffectsList,auroraCurrentEffect)
break
if auroraCurrentId < auroraEffectsSum then
auroraCurrentId = auroraCurrentId + 1
auroraEffect = get_value_for_key(auroraEffectsList,auroraCurrentId)
else
auroraEffect = 1
auroraEffect = get_value_for_key(auroraEffectsList,auroraEffect)
local payload = ‘{“select” :"’…auroraEffect…‘"}’
url = siteurl2,
method = “PUT”,
headers =
[/code]
I couldn’t get the luup code to work. My auth token is correct and I have the IP address. Any ideas? In the test luup code it says code successful so the code is running. I copied and pasted the code as is and put in my IP address and my auth token.
My code is as follows:
local http=require("socket.http")
local auroraToken = "xxxxxxxxxxxxxxxxxxxxxxx";
local siteurl = "http://192.168.x.xx:16021/api/v1/"..auroraToken.."/state/on/"
local siteurl1 = "http://192.168.x.xx:16021/api/v1/"..auroraToken.."/state/"
url = siteurl,
method = "GET",
headers =
["Content-Type"] = "application/json"
then
auroraOn = string.match(value, "%a+", 8)
if auroraOn == 'false'
then auroraOn = 'true'
else
auroraOn = 'false'
local payload = '{"on" : {"value":'..auroraOn..'}}'
print(payload)
url = siteurl1,
method = "PUT",
headers =
["Content-Type"] = "application/json",
["Content-Length"] = payload:len()
Gonna try working on this again today, but was wondering if anyone was looking at building a plug-in.
I would have thought this code would work. Anyway, please update us if you make progress. I’d like to tinker with my Nanoleaf too.
I’ve been able to create a batch file that works as well as a python script. Absolutely no luck on luup.
Python script looks like this:
import requests
url = "http://192.168.x.x:16021/api/v1/AUTHTOKEN/state/"
payload = "{\"on\": {\"value\": false}}"
headers = {
'cache-control': "no-cache",
'Postman-Token': "861a0138-2bb5-4108-xxx-8622e8ad2daa"
response = requests.request("PUT", url, data=payload, headers=headers)
print(response.text)
Is there any way to send a request to a server to run a python script on a raspberry pi from the Vera?
The code posted by Mobilniy works for me for on/off on my Nanoleaf triangles, but not for the next effect.
This was the only curl command I could get to run to turn them off in Windows:
curl -X PUT -H “Content-Type: application/json” -d “{"value":false}” http://YOURIP:16021/api/v1/YOURTOKEN/state/on
Anyone had more features via the Vera?
But now the same scene to toggle the power no longer works. Bizarre.
I ended up sending an event from Vera to EventGhost to toggle my light switch instead, and running the above curl .bat file from there instead.
