Hello, i just purchased a Vera Edge and i have a bunch of 1st version Heatmiser Wifi (Standalone, PRT-TS WIFI) to add.
i’s possible to have the plugin? Thanks
My Vera seems to have lost my heatmiser hub - not sure if anyone else has had this?
I get a ‘Lua Startup Failure Can’t Detect Device’
Any advice appreciated
hello
Would I be able to request a duplicate of the Neo/Vera Edge module please?
Still genuinely new so I can’t PM you from this side.
An abundance of thanks and value you making this accessible.
Lucky Patcher 9Apps VidMate
For anyone wanting a copy of the plugin, please check my earlier post for contact details.
has anyone successfully managed to control Heatmiser stats with PLEG to stop the heating when a door is open. I’ve failed so far
Not sure if you found the answer out or not but Alan’s plugin does work with the gen2 hub
I’ve had the Heatmiser plugin for some time, and used it during the winter earlier in the year without any issue. Tonight I went to change the set point in both the Vera app and through the web interface and neither o them work!!
Not a great deal has changed with my setup other than a few new lights added to the system. Anyone had a similar issue or can somebody suggest a fix?
The web interface is working this morning, after I changed the Poll Frequency from 30 to 15. The Vera Mobile app still doesn’t work and reports the devices as Locks!
Hello,
i am new to this forum. However i have Vera and heatmiser and PRT-TS WIFI thermostat.
How can i get a plug inn to control it.
Thank you
Cuk
