Would this also cause an issue where I can not set variables (not in drop down)? I pulled the sunrise/sunset logic out and used specific times instead? I have one variable called “watered” in a different reactor device.
*************************************************** REACTOR LOGIC SUMMARY REPORT ***************************************************
Version: 3.8-20262 config 20190 cdata 20045 ui 20190 pluginDevice 309 LuaXP 1.0.2enh
System: Vera version 1.7.5186 (7.31) on Sercomm G450 ID 36 (Vera Plus); loadtime 1625492700/1625492725; systemReady 1625492730
Env: Lua 5.1; JSON dkjson 1.2; UnsafeLua=nil/true
Local time: 2021-07-05T08:54:28-0500; DST=1; Headingley, Manitoba Canada; formats %d/%m/%Y %H:%M:%S
House mode: plugin 1; system 1; tracking on
Sun data: { “source”: “int”, “civdawn”: null, “nautdawn”: null, “sunset”: null, “nautdusk”: null, “stamp”: 2021183, “latitude”: -97.3304, “astrodusk”: 1625282498, “longitude”: -97.409, “civdusk”: null, “astrodawn”: 1625219130, “sunrise”: null }
Geofence: not running
RS: 1625284318,1625313073,1625344355,1625356831,1625400578,1625400750,1625424211,1625430754,1625483796,1625492725
NS: 1617632705:D,1617641040:U,1618128605:D,1618156980:U,1618921650:D,1618923060:U,1619110500:D,1619112900:U,1620978930:D,1620990000:U
WaterGarden (#446)
Version 20045.90 07/05/21 08:54:25
Message/status: Not tripped
Variable/expressions
0: watered 1 [last 1(number)]
Condition group “WaterConditions” (AND) false as of 08:51:23
&-T-service MSW-Wind (444) urn:micasaverde-com:serviceId:GenericSensor1/CurrentLevel < 7; output follow, delay reset for 1800s [3.1 at 08:51:23; T/T as of 08:51:23/08:51:23]
&-T-service MSW-Precipitation (445) urn:micasaverde-com:serviceId:GenericSensor1/CurrentLevel = 0 [0 at 08:51:23; T/T as of 08:51:23/08:51:23]
&-F-trange bet ,3,0,6,0 [1625493083 => 1625493265 at 08:54:25; F/F as of 08:51:23/08:51:23]
&-T-weekday { “id”: “cond162heu7n”, “type”: “weekday”, “value”: “1,2,3,4,5,6,7”, “operator”: “” } [2 at 08:51:23; T/T as of 08:51:23/08:51:23]
&-F-var watered isfalse nil [1 at 08:51:23; F/F as of 08:51:23/08:51:23]
Activity root.false
Device Faucet-back (49) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue=“0” )
Delay 21600 inline
Activity root.true
Device Faucet-back (49) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue=“1” )
Notify method nil nid 1: sid 78 users 1652881 message “Watering the garden for 30 mins.”; index=“2”
Delay 1800 start
Events
2021-07-05 08:45:25: Reactor startup (Luup reload)
2021-07-05 08:45:25: Starting (Luup Startup/Reload)
2021-07-05 08:45:26: Sensor update starting
2021-07-05 08:45:26: Sensor update completed; 0.289s
2021-07-05 08:45:39: Configuration changed!
2021-07-05 08:45:39: Sensor update starting
2021-07-05 08:45:39: Sensor update completed; 0.023s
2021-07-05 08:48:09: Configuration changed!
2021-07-05 08:48:09: Sensor update starting
2021-07-05 08:48:09: Variable test value changed from “0” to “0”
2021-07-05 08:48:09: Sensor update completed; 0.050s
2021-07-05 08:51:04: Configuration changed!
2021-07-05 08:51:04: Sensor update starting
2021-07-05 08:51:04: Sensor update completed; 0.068s
2021-07-05 08:51:12: Configuration changed!
2021-07-05 08:51:12: Sensor update starting
2021-07-05 08:51:12: Sensor update completed; 0.062s
2021-07-05 08:51:22: Restart action invoked; clearing state and restarting ReactorSensor
2021-07-05 08:51:22: Restarting
2021-07-05 08:51:23: Sensor update starting
2021-07-05 08:51:23: Variable watered value set to 1
2021-07-05 08:51:23: Condition cond0 test state changed from (nil) to true
2021-07-05 08:51:23: Condition cond0 evaluation state changed from (nil) to true
2021-07-05 08:51:23: Condition cond162h5ihe test state changed from (nil) to true
2021-07-05 08:51:23: Condition cond162h5ihe evaluation state changed from (nil) to true
2021-07-05 08:51:23: Condition cond162h6grp test state changed from (nil) to false
2021-07-05 08:51:23: Condition cond162h6grp evaluation state changed from (nil) to false
2021-07-05 08:51:23: Condition cond162heu7n test state changed from (nil) to true
2021-07-05 08:51:23: Condition cond162heu7n evaluation state changed from (nil) to true
2021-07-05 08:51:23: Condition cond16exiv1b test state changed from (nil) to false
2021-07-05 08:51:23: Condition cond16exiv1b evaluation state changed from (nil) to false
2021-07-05 08:51:23: Group WaterConditions test state changed from (nil) to false
2021-07-05 08:51:23: Group WaterConditions evaluation state changed from (nil) to false
2021-07-05 08:51:23: Preparing WaterConditions.false (root.false) activity
2021-07-05 08:51:23: Launching scene/activity root.false
2021-07-05 08:51:23: Starting “root.false” group 1
2021-07-05 08:51:23: Delaying scene root.false group 2 actions until 14:51:23
2021-07-05 08:51:23: Changing RS tripped state to false
2021-07-05 08:51:23: Sensor update completed; 0.124s
2021-07-05 08:54:25: Configuration changed!
2021-07-05 08:54:25: Stopping activity “root.false”
2021-07-05 08:54:25: Sensor update starting
2021-07-05 08:54:25: Sensor update completed; 0.022s
Devices
MSW-Precipitation (445) urn:schemas-rboer-com:device:WeatherMetric:1 (12/0); parent 439; plugin -; mfg model ; dev D_MsWeatherMetric.xml impl
Faucet-back (49) urn:schemas-upnp-org:device:BinaryLight:1 (3/0); parent 1; plugin -; mfg model ; dev D_BinaryLight1.xml impl
ZWave (1) urn:schemas-micasaverde-com:device:ZWaveNetwork:1 (19/0); parent 0; plugin -; mfg model ; dev D_ZWaveNetwork.xml impl
MSW-Wind (444) urn:schemas-rboer-com:device:WeatherMetric:1 (12/0); parent 439; plugin -; mfg model ; dev D_MsWeatherMetric.xml impl
Multi Weather Statio (439) urn:schemas-rboer-com:device:Weather:1 (25/-1); parent 0; plugin 9326; mfg model ; dev D_MsWeather.xml impl I_MsWeather.xml
Watches
Device #446 WaterGarden service urn:toggledbits-com:serviceId:ReactorSensor variable TestHouseMode
Device #445 MSW-Precipitation service urn:micasaverde-com:serviceId:GenericSensor1 variable CurrentLevel
Device #444 MSW-Wind service urn:micasaverde-com:serviceId:GenericSensor1 variable CurrentLevel
Device #446 WaterGarden service urn:toggledbits-com:serviceId:ReactorSensor variable cdata
Device #398 Hallway service urn:micasaverde-com:serviceId:ZWaveDevice1 variable AgiInfo
Device #408 Bathroom Light service urn:upnp-org:serviceId:SwitchPower1 variable Status
Device #446 WaterGarden service urn:toggledbits-com:serviceId:ReactorSensor variable TestTime
