Suggestions on setup?
So I ordered a veralite and am setting up my automation. So far I’ve got a trane thermostat and a Yale deadbolt. I’d like to add a security camera to the front door and contact sensors to the outside doors.
  • Are the zwave contact sensors worthwhile, or should I go for the DCS 1832 and the network module. I don’t really see using much motion sensing that I don’t already have built in wall switches for.
  • Should I go for something like a swann d1 nvr system, or just a single cam on the door. Seems a D1 nvr system would be more flexible, but I want to make sure these types of systems integrate okay. The single cam would be limited to mailing snapshots/motion detect/live viewing.
Similar question regarding door sensors here:
http://forum.micasaverde.com/index.php/topic,14737.0.html
Yah I saw that, thread. It said that for good motion sensors you should get one. I don’t really care about motion. Just the contact sensors. It is substantially more expensive to get an alarm panel just to use it for contact sensors however. If its a matter of cost, its not a winner for me even if the per sensor cost is less. However if zwave contact sensors (not motion) aren’t reliable it may be worth looking into.
See my post in the thread:
http://forum.micasaverde.com/index.php/topic,14737.msg112027.html#msg112027
