Suddenly getting notifications
About a week ago I started getting notifications when my reactor conditions are met and unmet. I don’t have notifications for them turned on and haven’t made any changes to the Vera controller in ages. Did something change with Reactor or Vera recently to cause notifications to be activated? Any ideas how to stop this?
TIA
@rigpapa
It’s a Vera/Luup “feature”. Go into My Modes from the Dashboard, under “What to do if an armed sensor trips?”. Your Reactor Sensors should not be armed, and if for some reason you want them armed (e.g. using arming of the RS as part of your logic), then you can turn off the notifications in that section. Luup will also arm the sensors with house mode changes, which you can control from the same My Modes page (i.e. turn that off).
Ah, that was it. Thank you!
