Vera2, firmware 1.1.1245 connected to a linksys WRT54GS. I have also submitted a ticket to support. Figured I’d try here as well.
Running well until this morning. I couldn’t access Vera through Homebuddy, cp.mios.com, remotely or locally.
It’s helped in the past, so I tried deleting and re-adding the unit from the MyMios screen. I was able to delete it. When I try to add it again, MyMios finds it (IP 192.168.1.100), then it just stalls at the “trying to connect” screen.
I also tried adding it via micasaverde.com/vera2 with the same result… It finds it, but says it cannot communicate with Vera.
Multiple PDPU’s (power down/power ups) of both Vera and my router have not helped.
Any suggestions?
