Struggling with basics
Hello, I’m trying to get to grips with PLEG; I think if I can get one initial thing to work I’ll understand it a lot more.
I have a Conexis lock and z-wave lighting and I simply want to trigger my hallway light to come on if it is dusk and if the front door gets unlocked.
Therefore, I assume I need the following:
sDarknessHours - a schedule/timer for dusk to dawn
tFrontLock - a device trigger for the front door opening
Next up is where I find things confusing. Do I need a Condition/Automation Logic? And if so, how should this be written?
And finally, when that Condition is met I make a Logic Action to turn on the hallway light?
And if PLEG is armed, this will all automatically run 24/7/365?
Thank you all so much for your help.
I found this very helpful: http://forum.micasaverde.com/index.php/topic,21603.0.html
And yes, if the PLEG device is armed, it will run 24/7/365.
