Happy New Year
I am new to home automation and I am struggling to find the right diagram to support the installation of an Aeon Micro Switch G2 on a 3 way circuit. I have found many great diagrams on the forum, but not one that supports my wiring. I have been successful installing a Micro Switch on a single switch circuit.
Basically I am trying to figure out in which box should I put the Micro Switch. I am trying to find a solution that does not require pulling additional wire.
Box 1
14/2 from circuit box
14/3 between boxes
Box 2
14/3 from Box 1
14/2 to load
Connections
14/3 Black and Red wires join each of the three way switches (to the top two connections on the switch)
Neutral/White is tied from circuit box through to load across the 14/3 white wire
Black from power connects to switch 1
Black from load connects to switch 2
- Can I connect a micro switch without running additional wires?
- In which box do I put the switch?
- Which wires connect to what?
Thank you for any assistance.
