So, I have three Evolve LRM-AS dimmers installed. They all work when operated manually - including the dimming.
I was able to include them into network by walking the VeraLite in battery mode and adding them.
When I log onto the dashboard, I am able to see them.
However, I see a bright red light on the top left of each switch, with a note saying “unable to get any information on node”.
I have tried several actions on the dashboard including…
[ul][li]Excluding and re-including in the network[/li]
[li]Running the “heal” program[/li]
[li]Moving the VL a lot closer - it is about 25ft away now - and I can’t get it any closer[/li][/ul]
It looks like the VL is just not communicating to the switches - and it isn’t a range issue.
I would appreciate any pointers you may have.
