Guys,
I am just stumped.
I’ve had my Powermax Plus working well with my Vera 2 for well over a year. No problems at all.
I’m using a USB to RS232 converter with the correct drivers, and a DB9 to RJ45 Cisco console adapter cable to connect to the Powerlink port on the alarm.
A few weeks ago, I came home to my alarm being without power, internal battery depleted, and I assumed that the 9V AC power adapter died.
I purchased another power adapter, and the alarm comes up fine, recognizes all zones, etc. However, when I plug the serial cable back into the Powermax+ (for between the Powermax+ and Vera 2), the power light on the alarm turns off, and it starts draining the battery. Just by plugging the cable back in between the 2 systems. If I disconnect the cable from the Powermax+, the power LED comes back on, and everything seems normal again (except I need to connect so I can use with Vera and this plugin that I love so much).
I bought another cable, and even a new USB adapter (on the compatibility list for Vera as plug and play), and it does makes the Powermax+ go into some kind of power failure mode. For chance, I plugged the PowerLink module back in to see of that would drag the power down into fail, and the PowerLink came up just fine, and established comm. This is perplexing. Why would a PowerLink still work fine, yet a previously tried and true connection method (even with new cables/adapters) causes the Powermax+ to go into a power failure mode?
Man, I’d hate to have to buy a new alarm to get this going again. Re-zoning a new alarm to a large installed sensor count is going to suck. Any suggestions, or has anyone been through this?
