I use the Ezlo plus controler. Update to last firmware 2.0.30.2041.2
I bought 2 Stelpro STZB402+ thermostat to control baseboards heaters in my cottage.
Thermostat version 14, Manufacture date 14 march 2019
Since this exact device shows up in the add device ->Thermostat, I bought it guessing it would be well supported.
The device pairs OK (either when choosing the STZB402 device or Generic Zigbee) and I can set the temperature but:
the room temperature is not updated in the UI and there is a message saying Device fails to communicate showing constantly.
The status of the device in the UI turns to the OFF mode after a certain time although on the device itself the status does not change.
I tried Pairing multiple times with same result.
Is this device really Supported? Can I expect an Ezlo plus firmware version that works?
