Stat controlling socket switch
Hi all,
I’m new to zWave so it may well be a basic question, however I am a bit stumped. I have an electric heater in my showroom which I would like my thermostat (Secure SRT321) to switch on/off via a socket switch.
I have the scene created to switch it on, and am setting the trigger as the stat, but I am unsure as to how to program it from there, it gives me only the options of 'ambient temp goes below/above/is reached etc.
How do I program so when heat is called it will switch on the heater? And likewise when the set temp has been reached??
The plugin for your thermostat may not have triggers defined when the thermostat calls for heating or cooling or returns to idle. I added these to the Nest thermostat plugin recently (see https://github.com/watou/vera-nest-thermostat/commit/c777802dbdf50dae5908e71ebe075e3cc73a8184).
If needed, you or the plugin author might be able to add something similar to your thermostat’s plugin.
watou
You can use PLEG … Program Logic Event Generator … plugin.
There was a previous post that a person has a FAN he wanted to turn on when ever the HVAC was on. I guess it was to help circulate the air.
In PLEG you would need to have an INPUT Device Property attached to the ModeState variable of the Thermostat … call this ModeState.
Then you would have two conditions in PLEG:
SwitchOn ModeState eq ‘Heating’
SwitchOff Not SwitchOn
Then add appropriate Actions to the above Conditions … to actually turn the switch on and off.
