I have a Reactor sensor set up to start my Sonos when the door opens and when Home Mode = Home. However, there are situations in which I open this door many times within a short period of time. Since I don’t want the music to start each time I open the door, I added a dependency that requires the music to have been stopped (or, not playing) for at least 10 minutes when the door opens for the group to be true.
This doesn’t really do what I want, though. If I open the door every minute for 10 minutes, the music will start on the first and the 10th time. What I really want is for that “timer” to reset each time the door is open. If I open the door every five minutes for an hour (or more), the music should not start after the first time. But if I’ve not opened the door for at least 10 minutes, the music should start.
I added a logic summary, showing some activity from yesterday, when I was going in & out and manually stopped the music once or twice upon entry. What changes do I need to make to support this requirement? Thanks! ![]()
*************************************************** REACTOR LOGIC SUMMARY REPORT ***************************************************
Version: 3.0 config 301 cdata 19082 ui 19125 pluginDevice 9
System: Vera version 1.7.1040 on Sercomm NA900; loadtime 1557958062; systemReady 1557958108; Lua 5.1
Local time: 2019-05-16T09:34:36-0400; DST=1
House mode: plugin 1; system 1; tracking on
Sun data: { "stamp": 2019136, "civdawn": 1558001682, "nautdawn": 1557999847, "sunset": 1558051969, "nautdusk": 1558055338, "latitude": 27.9110297, "astrodusk": 1558057254, "longitude": -82.5219683, "civdusk": 1558053503, "astrodawn": 1557997931, "sunrise": 1558003216 }
Geofence: running in quick mode, last update 07:38:00, data version 2
User 2035691 ishome=0 inlist= since=07:38:00
Raw: { "updated": 1558013640, "users_settings": [ { "id": 2035691, "ishome": 0 } ], "mode": 1 }
Shed Music (#32)
Version 19082.1558013520 05/16/19 09:32:00
Message/status: Not tripped
Condition group "Mode = H, Shed Music not playing , Shed Door opened" (AND) false as of 19:53:07 <root>
&-T-housemode in 1 [2 => 1 at 08:41:31; T/T as of 08:41:31/08:41:31] <condcbvr6z9>
&-T-service Sonos - Shed (29) urn:upnp-org:serviceId:AVTransport/TransportState <> PLAYING for ge 600s [paused_playback => stopped at 20:54:27; T/T as of 19:54:27/09:06:06] <condcbwwws8>
&-F-service Shed Door (12) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 1 after condcbwwws8 [1 => 0 at 19:58:53; F/F as of 19:58:53/19:53:07] <condcbvrluh>
Activity root.true
Device 29 (Sonos - Shed) action urn:micasaverde-com:serviceId:Sonos1/PlayURI( URIToPlay=SF:Chris Stapleton Radio, Volume=40 )
Events
05/15/19 18:07:53 start:
05/15/19 18:09:18 devicewatch: device=29, old="PLAYING", name=Sonos - Shed, var=urn:upnp-org:serviceId:AVTransport/TransportState, new="STOPPED"
05/15/19 18:09:19 condchange: newState=true, cond=condcbwwws8, oldState=false
05/15/19 18:19:19 evalchange: newState=true, cond=condcbwwws8, oldState=false
05/15/19 19:53:04 devicewatch: device=12, old="0", name=Shed Door, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="1"
05/15/19 19:53:05 condchange: newState=true, cond=condcbvrluh, oldState=false
05/15/19 19:53:05 evalchange: newState=true, cond=condcbvrluh, oldState=false
05/15/19 19:53:05 condchange: newState=true, cond=root, oldState=false
05/15/19 19:53:05 evalchange: newState=true, cond=root, oldState=false
05/15/19 19:53:05 sensorstate: state=true
05/15/19 19:53:05 startscene: scene=root.true, sceneName=tripactions
05/15/19 19:53:05 runscene: scene=root.true, sceneName=tripactions, group=1, notice=Starting scene group 1
05/15/19 19:53:06 devicewatch: device=29, old="STOPPED", name=Sonos - Shed, var=urn:upnp-org:serviceId:AVTransport/TransportState, new="TRANSITIONING"
05/15/19 19:53:06 endscene: scene=root.true, sceneName=tripactions
05/15/19 19:53:06 devicewatch: device=12, old="1", name=Shed Door, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="0"
05/15/19 19:53:07 condchange: newState=false, cond=condcbvrluh, oldState=true
05/15/19 19:53:07 evalchange: newState=false, cond=condcbvrluh, oldState=true
05/15/19 19:53:07 condchange: newState=false, cond=root, oldState=true
05/15/19 19:53:07 evalchange: newState=false, cond=root, oldState=true
05/15/19 19:53:07 sensorstate: state=false
05/15/19 19:53:11 devicewatch: device=29, old="TRANSITIONING", name=Sonos - Shed, var=urn:upnp-org:serviceId:AVTransport/TransportState, new="PLAYING"
05/15/19 19:53:12 condchange: newState=false, cond=condcbwwws8, oldState=true
05/15/19 19:53:12 evalchange: newState=false, cond=condcbwwws8, oldState=true
05/15/19 19:53:48 devicewatch: device=12, old="0", name=Shed Door, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="1"
05/15/19 19:53:49 condchange: newState=true, cond=condcbvrluh, oldState=false
05/15/19 19:54:16 devicewatch: device=12, old="1", name=Shed Door, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="0"
05/15/19 19:54:17 condchange: newState=false, cond=condcbvrluh, oldState=true
05/15/19 19:54:26 devicewatch: device=29, old="PLAYING", name=Sonos - Shed, var=urn:upnp-org:serviceId:AVTransport/TransportState, new="PAUSED_PLAYBACK"
05/15/19 19:54:27 condchange: newState=true, cond=condcbwwws8, oldState=false
05/15/19 19:58:26 devicewatch: device=12, old="0", name=Shed Door, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="1"
05/15/19 19:58:27 condchange: newState=true, cond=condcbvrluh, oldState=false
05/15/19 19:58:52 devicewatch: device=12, old="1", name=Shed Door, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="0"
05/15/19 19:58:53 condchange: newState=false, cond=condcbvrluh, oldState=true
05/15/19 20:04:27 evalchange: newState=true, cond=condcbwwws8, oldState=false
05/15/19 20:54:26 devicewatch: device=29, old="PAUSED_PLAYBACK", name=Sonos - Shed, var=urn:upnp-org:serviceId:AVTransport/TransportState, new="STOPPED"
05/16/19 07:37:43 devicewatch: name=Reactor, var=HouseMode, device=9
05/16/19 07:37:44 condchange: newState=false, cond=condcbvr6z9, oldState=true
05/16/19 07:37:44 evalchange: newState=false, cond=condcbvr6z9, oldState=true
05/16/19 08:41:30 devicewatch: name=Reactor, var=HouseMode, device=9
05/16/19 08:41:31 condchange: newState=true, cond=condcbvr6z9, oldState=false
05/16/19 08:41:31 evalchange: newState=true, cond=condcbvr6z9, oldState=false
05/16/19 09:00:29 configchange:
05/16/19 09:00:30 evalchange: newState=false, cond=condcbwwws8, oldState=true
05/16/19 09:01:07 configchange:
05/16/19 09:06:05 configchange:
05/16/19 09:06:06 evalchange: newState=true, cond=condcbwwws8, oldState=false
05/16/19 09:31:56 configchange:
