I have an ST814 setup in Homewave showing temp and humidity perfectly. I also have a multi value display setup in the corner of the screen which shows my battery level via the “BatteryLevel” variable. My question is the display only shows the “number” in Homewave. Is there any way to format it so that it shows a percentage sign after the number such as 75% instead of just 75? Not a huge deal just wondering if that could be done. Thanks.
Scott
