ssh using root
I am having issues logging on to my Vera using PUTTY and username “root”. I followed everything according to the instruction provided but keep getting “Access denied”. I am trying to clean a few luup files but when I followed the workaround to connect using remote rather than root, I am able to get in. Using the command nvram show | grep pass, I can see the root password which is exactly what I typed when using root, I am still getting access denied. Can some share some light as to why this is happening?
Thanks in advance.
You can use the remote login that you used to get into vera to do what you need to do.
  • Garrett
Thanks Garrett but is there a reason why I can’t login using the root credentials?
Perhaps with the help of remote login you might find it possible to set up a SSH keypair between your development machine and Vera by running ssh-keygen (not on Vera) and copying the public key to Vera /etc/dropbear/authorized_keys as described here:
http://forum.micasaverde.com/index.php/topic,14910.msg113230.html#msg113230
This will enable you to ssh / scp to your Vera without having to remember your root password to login or copy files across.
The nvram command shows the root password as it would have been when your Vera was born. If anyone (even a previous owner) ran the passwd command to change the password then it will no longer match.
There could be other reasons too, related to your SSH client’s use (or not) of SSH protocols or authentication mechanisms. If you run your SSH client in verbose mode it will give you more information.
