SSH on iPad - Direct File Transfer To Vera - How To?
Hi
As I use Textastic on the iPad to edit my xml files, I have to mail them to myself so i can then upload them from a PC (via the Vera UI) as Vera does not support a direct transfer via FTP/SFTP.
Does anyone know of a way I could move the files i’ve edited on an IPAD to Vera?
I have some SSH apps on the Pad too, so could I do a work around uploading the file to a Linux NAS I have and then carry out an SSH file transfer to Vera (not being Linux savy could someone advise on the steps/cmd line entries) ?
The goal is to avoid the need for a PC…
I have updated the subject line to reflect the discussion on SSH file transfers should anyone find it of use interest when searching the forums.
My “transfer” script goes:
#!/bin/sh
for f in "$@"; do
  scp "$f" root@my-vera-hostname:/tmp
  f="${f##*/}"
  ssh -x root@my-vera-hostname pluto-lzo c /tmp/"$f" /etc/cmh-ludl/"$f".lzo
done
I run it from the command line like this:
./transfer L_MyPluginFile.lua I_MyPluginFile.xml [...]
The trick is in getting the scp/ssh commands to not prompt you for a password. You do this by generating a public/private keypair and putting the public key into /etc/dropbear/authorized_keys. You’re going to struggle horribly with this and I’m not going to be much help. Fortunately this isn’t Vera-specific so you have all of Google to help you.
You’re getting to know me so well :slight_smile:
Thanks @futzle
I have a vague idea what it’s trying to do, but it seems to suggest all of it runs on Vera, however I cannot reference any files stored on the iPad so I would need to use Textastic to send my updated xml files to a share on my NAS //192.168.x.xx/media/Vera
Therefore i assume that script would need to be created on the NAS and then be run from there??
How would it need to change if I want to send the file from the NAS to Vera? Or does Vera go off and get it ??
Looking online …
It seemed to suggest that the following cmd line entry run on Vera might work, but it did not work for me.
scp root@192.168.111.111:/home/Share/I_XAP.xml /etc/cmh_ludl/
It gave me the option of accepting some form of fingerprint? Although @futzle’s example suggests that the file format i’m want to transfer needs to be .lzo?
[code]scp root@192.168.111.111:/home/Share/I_XAP.xml /etc/cmh_ludl/
Host ‘192.168.111.111’ is not in the trusted hosts file.
(fingerprint md5 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx)
Do you want to continue connecting? (y/n) y
/usr/bin/dbclient: Connection to root@192.168.111.111:22 exited: No auth methods could be used.
[/code]
Subsequent attempts just show this.
I’m assuming it’s password related (and from what i can tell i can’t include the password in the line enty) so will keep digging and try an use @futzle’s script.
parkerc, you are going in the right direction. Yes, I develop on a Unix machine, so I run the script directly on that, but in your case you could run it on the NAS, assuming that it has a shell prompt (most do).
Getting around the auth errors is probably the last hurdle. The general process is that you create a keypair (Google “ssh-keygen”). Put the private key on the NAS and put the public key on the Vera in the file /etc/dropbear/authorized_keys (create it if needed). There’s more but I will drip-feed it to you to avoid overload.
I use iSSH on the iPad to do shell sessions. It can generate SSH keypairs too.
I bet you want:
scp /home/Share/I_XAP.xml root@192.168.111.111:/etc/cmh_ludl/
since you are copying from the NAS to Vera.
(Also note that in my script I stage the file to /tmp on the Vera because the files in /etc/cmh-ludl need to be compressed.)
I bet you want:
since you are copying from the NAS to Vera.[/quote]
In that example I was trying to run the scp request on my Vera to see if it could go off and get the file on the NAS (which is 192.168.111.111) , I just wasn’t sure which is the best way round to do it…
Regarding ssh keygen I’ve found this online - http://rcsg-gsir.imsb-dsgi.nrc-cnrc.gc.ca/documents/internet/node31.html which seems to talk me through the process, so I will give it a go.
I work in IT but have had little exposure to the details of pub/priv keys, so this is a good learning curve…
Finally if I move the XAP.xml to a temp directory on Vera, how do I then move it into the /etc/cmh-ludl/ so it can be referenced as it needs to be compressed? Is that another special cmd line entry?
That’s the pluto-lzo command’s job:
pluto-lzo c source-file.xml target-file.xml.lzo
It makes a new file, which can be in a different directory. Two birds with one stone.
Hi @futzle
Here’s what I have done so far…
[ol][li]I created the folder as suggested. (mkdir etc/dropbear/authorized_keys)[/li]
[li]On the NAS I created the public/private keys (ssh-keygen -d)[/li]
[li]Then with the public and private keys are saved to ~/.ssh/id_dsa.pub and ~/.ssh/id_dsa, respectively. I next copied the public key to Vera (scp ~/.ssh/id_dsa.pub root@192.168.1.xxx:.etc/dropbear/authorized_keys[/li]
[li]assuming all was well, I tried to copy a file over to Vera (scp /home/Share/I_XAP.xml root@192.168.1.xxx:/etc/) BUT it still prompts me for the Vera root password ?[/li][/ol]
In summary, it looks like I can transfer a file from my NAS to Vera (hooray!!) thanks for your help on that, although everything I read suggests that it should not prompt me for a password now the NAS and Vera has a key ?? (Any thoughts)
Additional - I also noticed that Textastic will allow me to point to a public key on Vera when doing SSH, theoretically allowing me to do a direct transfer, but i put the following location in (etc/dropbear/authorized_keys) it fails, telling me it cant find the file.
Now I assume that’s either because I don’t have the private key on my iPad ?! Although delving a bit deeper - it doesn’t look like Textastic supports SCP so that’s probably the reason…)
Textastic has problems with SCP. I contacted the developer last year and he said a future release would fix things, but no luck yet, despite at least one release since then.
authorized_keys is a file, not a folder. It contains all of the public keys that are allowed to connect without a passphrase, concatenated one per line. Since you only have one public key you can just rename id_dsa.pub to authorized_keys on the Vera and put it in the /etc/dropbear directory.
Do i need to rename id_dsa.pub to authorized_keys ?
/etc/dropbear# ls [b]authorized_keys [/b] dropbear_dss_host_key dropbear_rsa_host_key id_dsa.pub
I’ve copied the public key file (above) across from the NAS to Vera again and retried an scp transfer request (scp /home/Share/test.xml root@192.168.1.xxx:/etc/etrayz/), but it still prompts for a password ?
Yes. Delete (rmdir) the bogus authorized_keys directory; it’s getting in your way.
Done.
/etc/dropbear# ls authorized_keys dropbear_dss_host_key dropbear_rsa_host_key
And tried the copy again and it works !! No password prompt :slight_smile: - Thanks futzle .
To help my learning…
Why does the file need to be renamed to “authorized_keys” ?
If I want to link to another PC what do I call the other one? E.g, authorized_keys2 ?
[quote=“parkerc”]Why does the file need to be renamed to “authorized_keys” ?
If I want to link to another PC what do I call the other one? E.g, authorized_keys2 ?[/quote]
So you just append the second public key after the first one, with a text editor. A public key is just one (long) line of text.
I don’t know what design decisions in OpenSSH led to them making authorized_keys a file rather than a directory. That’s just the way it is.
