Hello,
I’m trying to finalise the SRT321 installation with my Vera Lite (UI5 - last FW)
I’ve followed http://www.vesternet.com/resources/application-notes/apnt-20#.VD2P-fl_umE
I’m able to change the setpoint in Vera UI, it’s updated a few minutes after on thermosthat
Room temperature is displayed in Vera UI
Thermostat is working well with relay switch
But, if I change the setpoint using thermostat, the setpoint value isn’t updated in Vera’s UI.
I’ve tried to delete - recreate the device many many times. But I wasn’t able to change the setpoint’s display using the thermostat.
Has anyone else experienced this?
Many thanks for your help
One complementary point, if I use DataMine to display SetPoint and the value is correctly updated in real time !
It’s only the display of Setpoint value in Vera’s UI.
O.
Try reloading the browser - it’s not ideal I know, but I’ve seen the display being cached when the values are different. Also worth checking what the ‘real’ value is under the device, advanced settings - my bet is that’s correct and the same as the Datamine value.
thank you very much for your reply.
I’ve trying to reload the brower’s page, but I still got an old setpoint value.
Actually, the setpoint is 7? and the device is displaying 10?
I’ve checked in the Advanced folder, and the values are correct :
- setpointtarget 7
- currentsetpoint 7
- currentsetpoint 10
It looks like a refresh issue but I’ve no idea how to force the device to retrieve the currentsetpoint value.
Kind regards,
O.
