I’m running squeezebox plugin version 2.0 on ui5 and ui7 and everything works great without adding security/authentication to the server. But as soon as the authentication is enabled the plugin is unable to connect.
I’ve added the user/pass variables to the plugin and is able to connect now but is not sending any commands to the players. I believe is because the plugin is sending the commands without the authentication.
Is this a known issue?
