Just wondering has anybody successfully integrated any options to control Spotify on a squeezebox duet via Vera ?
Ive been trying to get it to play a playlist on spotify, but no go, I have it playing a local file
If anyone has ideas on how to do this I’d love to hear it
For anyone still looking to use Spotify within LMS controlled via Vera and start a playlist, I’ve managed to do it this evening. I am using the 3rd party Spotify plugin in LMS.
You need to add your Spotify playlist to your LMS favorites as I couldn’t get a playlist to start but favorites do.
Click on the name of the Favorite and you should then see the URL for the playlist, copy this into the LUA code below replacing the BOLD text and obviously replace IP address with your LMS server IP and MAC address to the address of the client you wish to control.
I’ve used the following LUA in a scene:
socket=require(‘socket’)
local client = socket.connect(‘192.168.0.110’, 9090)
client:send(“b8:26:eb:c1:71:f0 playlist play spotify:user:takethatofficial:playlist:7o1E5PXj3e0KNOUgRaU56A\n”)
local result=client:receive()
I hope this helps someone else ![]()
Here is the code I finally got working
socket=require('socket')
local mac = "00:04:20:99:92:8b"
local client = socket.connect('192.168.1.227', 9090)
-- Make sure the player is on:
client:send(mac .. " power 1\n")
-- Play Spotify Playlist
client:send(mac .. " playlist play Playlistname-Spotify\n")
client:send(mac .. " mixer volume +30\n")
