Hi, I’d like to Know if Square Connect can be included in a Fibaro system.
As it is a Zwave and use IP too, I’s like to use it as a blaster. Is it possible?
You can use it in a HC2, but not aware of including it. The SQ blaster will listen to http commands that you can send.
Have a read in this post: [url=http://forum.fibaro.com/index.php?/topic/15719-ir-integration/?hl=blaster]IR integration - Scenes and Interface - Smart Home Forum by FIBARO
