[quote=“Maartenvt, post:10, topic:165787”]Oke, i downgraded vera to 1.1.228 still it crashes.
It is strange, it worked great with this configuration (Vera 1.1.228 and Ipod 3.1.2)
I don’t know what the problem is.[/quote]
@Maartenvt
If I understand, you had this config and it worked… did upgrades, downgrades and now it doesnt work still?
We have a couple of files that we hold between sessions that are read at start up. I am concerned that one of these is now corrupt or out of step with the various versions. It is possible that this is causing the crash.
The first is a file we get from vera when we first do device discovery. Basically when we launch we use findvera.com to see if you have any local veras. If we do, we pull your configuration and get a couple of key pieces of data plus what devices you have configered etc. We do a compare on subsequent loads, to see if anything has changed. Of particular interest the first time is which specific findvera server your particular vera unit uses… (hence there are some tricky use cases around this).
What I have found is that sometimes when switching between versions of vera and the app, this file gets corrupted or confused and this could be the case. It is very hard to create reproducible test cases for these behaviours… especially as ther is still such turbulance in the Vera Firmware version. As I mentioned in another post, when we get a build that the majority of our users feel is stable and works for them, we will make that the gold support firmware and then go into planned, structured testing of firmware releases that we will support SQ Remote against.
For now, I would ask that you make sure you delete the app from the iPod touch before re-syncing… then reinstall the app. Be warned that the control pads will be deleted… If you had saved to box.net, you can download using the sharing option… and if that then casues problems, we know that somehow the control pads had got corrupted. As you have already purchased the license, you can restore the license from setup->feature sets-> restore purchased feature sets.
It will, of course be best, if you can, to do this locally on the same Network as the vera…
Mat
