I assume Sq blaster and SQ remote is the best IR remote interface that works with the vera to seemlessly control everything from lights, locks to AV equipment. I cant seem to find where to buy this and has stock. Is this the best option? Any suggestions would be appreciated.
Ditto. I’ve been trying to find one but there’s none in stock. I know they’re working on the sq connect controller… Have they discontinued the SQ Blaster Plus?
No we have not discontinued the blaster, we have had terrible supplier problems, which led us to run out of stock. Small companies are at the bottom of the pecking order sometimes when push comes to shove, and we were shoved. We expect to have more stock on Amazon very shortly (2 weeks or so, as Amazon have to process the incoming stock).
Yes…
because you will add itach to your vera…
and sqremote has control about devices inserted on vera and scenes created.
then you can insert in the screen on sqremote one button to activate and deactivate your itach.
