I use SQ blaster for IR and my Vera. Both have worked instantly so far. But since about a month my Vera control takes anything up to 30 seconds, although it sometimes is still instant. It is quite annoying though when you turn on lights, and nothing happens for about 30 seconds… I have got no idea why this is happening or what to do. IR control is still instant. Network (wifi) connectivity of my iPad and blaster is excellent, they are in the same room as an access point, iPad shows full strength wifi.
It would be worthwhile checking your MiOS/Vera logs when this happens.
ie. looking at the /var/log/cmh/LuaUPnP.log file for the time period covering the requested IR event.
In the cases that I’ve observed, “delayed” scenes are more often due to Vera being stuck in a restart and/or reboot process at the time of the event. In some cases, the reason it’s restarting/rebooting is the actual scene itself that’s being requested of it.
Problem solved. It was my router causing the problems. A Virgin media superhub, apparently is known for causing problems with apple and gcm messages. Changed my router, everything back to normal.
