[quote=“guessed, post:9, topic:171733”]I’ve added a Parameter that can be manually setup, for folks that want to change the reporting/polling period.
The Variable has the following details:
ServiceId: [tt]urn:squareconnect-com:serviceId:SQBlaster1[/tt]
Variable: [tt]Period[/tt] (datatype Number, units Seconds, default [tt]60[/tt])
Folks can manually create this under the Advanced tab of the Device, and give it a value (seconds) that is used for the delay between refreshes of the SQBlaster/SQBlaster+ data. The default is 60 seconds.
This is checked into SVN under the revision:
http://code.mios.com/trac/mios_sqblaster/changeset/49/
with the raw source:
http://code.mios.com/trac/mios_sqblaster/export/49/trunk/I_SQBlaster1.xml
When I next get around to publishing the plugin to apps.mios.com, this will be included. Otherwise people can use the old techniques to upload it if they want to try this functionality.
[quote=“guessed, post:2, topic:171733”]The newer SQBlaster+ models have a Temperature Sensor. It’s not listed in the featureset but it’s there.
The frequency of polling is to keep the Temperature Sensor data reasonably current so people can make decisions off it (turn of AV Gear, alert people, control Forced-air systems etc).
It’s currently wired into the Plugin code, with no method to override it (but I’ll consider adding it in a future release)[/quote][/quote]
Thank you for the fat support.
Do you know when you will release in the app store?
Otherwise I can upload manually the xml, change it in the devices. Then where should I add the parameter and in which exact field? Maybe a screenshot?
Thank you!!!
Matteo
