Speech synthesis on VeraLite
root@MiOS_3510xxxx:/tmp# flite -t "This is a very interesting test of speech synthesis" -o x.wav
[tt]flite[/tt] for VeraLite is available from [tt]http://downloads.openwrt.org/snapshots/trunk/ramips/packages[/tt]
[tt]http://wiki.openwrt.org/doc/howto/usb.audio[/tt] - or use a Squeezebox player or a Sonos player to play the output file …
Hi
Is it only for Vera Lite?
Not tested on Vera V3, but should work. IIRC, [tt]flite[/tt] is the biggest package from the repository (7 MB). So it might be more feasible to run the synthesis on a separate machine …
Hi
how you install flite, kmod-usb-audio ?
I can’t install this package on my Vera Light.
Unknown package ‘flite’.
Unknown package ‘kmod-usb-audio’.
Thank you
Andrey
