I have finally found documentation regarding Sony’s API to control my AVR. Unfortunately, for me, it uses JSON. Can someone please provide me with some simple instructions for getting a vera scene to post JSON?
I was able to change the input device using POSTMAN:
Not directly related, but my STR-DN1080’s network connections stopped working like 4 years ago, both wi-fi and cable. Wi-fi was going in and out over about a month and then just would not connect. The AVR network connection is greyed out like the card fried or disconnected.
I opened up the unit to see if something became loose but nothing was amiss. I spent weeks scouring the Internet looking for anyone having a similar issue. Not wanting to take it to a shop, I just gave up.
You had or heard of someone having a similar experience?
To use POST requests you would need to write some LUA code and at the moment quite a bit to make use of the LUA standard requests library. You can find an example using a post request here: [url=https://github.com/reneboer/openLuup-CarNet/blob/master/src/L_CarNet1.lua]https://github.com/reneboer/openLuup-CarNet/blob/master/src/L_CarNet1.lua[/url] lines 280-342. You probably can trim things down to your specific need.
Note that there is a luup.request documented in the wiki, but that is likely to crash the LUA engine of your Vera in the current Vera release.
Cheers Rene
