[quote=“Peraverde, post:79, topic:169644”]Thanks a lot Anker, Guessed and the others.
It works!!!
Not only UI4 but UI5 as well.
I tried few versions of luua files and this one works on Vera2 and Vera3.
Play, Stop, Mute, Mute(2nd), unMute, SkipDown, SkipUp, Pause, Down and Up (volume) functions work very well,
but FastForward, Rewind, Slow seems not working.
And I don’t understand the other commands ChapterUp, ChapterDown, DiskDown, DiskUp and GetTransportInfo.
What are they for?
How to use them?
I would like to make Sonos to play chosen audio file.
It would be nice when you leaving the house, to hear voice: “Window is open in the bathroom, please close it.”.
Anybody knows how to do it?[/quote]
Hi Peraverde,
Glad that you can use it!
The two different mute’s are to align to the Sonos and align to upnp. The Sonos1 mute is a typical Mute, but the one Volume1 is a mute/unmute toggle. Therefor the two different ones.
About the ChapterUp, ChapterDown, DiskDown, DiskUp commands. these are part of the standard MediaNavigation implementation on Vera. Doing this enables the plugin to work for example in other standards such as the iphone control point applications for Vera.
These are all listed, but not implemented in the sonos plugin! @guessed guided me on this and I trust his judgement
The following actions has been implemented in the plugin:
Play, Pause, Stop, Mute, UnMute, SkipDown (Sonos Next command), SkipUp (Sonos Previous command), Up (Volume, Down (Volume)
the rest has no functionality as I have not found any Sonos related actions that would macth these.
GetTransportInfo is something I need to remove…
I am looking into a SetVolume action, but this involves a new way of programming the plugin. I hope to get this working soon. Will keep you posted.
The request to be able to play a specific song is a bit more hard to implement from what I can understand of the Sonos protocol. Will look into this at a later stage.
Regards,
anker
