I have managed to create a Sonos plugin with basic functionality (version 0.1). As I am not a programmer whatsoever this has been made primarely based upon other plugins and code samles.
Hope you can use it. Feel free to contribute ![]()
[size=14pt][size=10pt][b]
EDIT: Status and code no longer maintained in thris thread. The status and code has been moved to the
Plugin code site: Sonos Wireless HiFi Music Systems
[s]
This plugin allows you to control your Sonos via Vera scenes.
Development Status
- Supported Models: ZP80 and ZP100 tested
- Supported and tested features (no guaranties though):
Supported Functions: Play, Pause, Stop, Previous, Next, IncreaseVolume, DecreaseVolume, Mute, UnMute, SetFileToPlay, SetVolume
What you need
-Vera with UI4 has only been tested, but at least one user has told me works on UI5.
- A Sonos Zone
- The 4 plugin files found in the trunk: / ā Sonos Wireless HiFi Music Systems
Upload the plugin files:
- In the Toolbox section open MiOS Developers >> Luup Files and upload all the files you downloaded. check the Restart Luup after upload checkbox and click GO.
Create the Sonos device:
- Open Create Device.
- In the UpnpDevFilename input box enter D_Sonos1.xml.
- In the Description input box enter a name for the panel device, e.g. Sonos Livning Room.
- Click Create device.
- Close this window and Save.
Configuration
- In the Sonos device advanced control tab specify the IP Address of your Sonos Zone in the āipā field.
- Now actions are available in scenes.
/anker[/s]
