Sonos plugin - version 1.1 released
The version 1.1 of the Sonos plugin is now available.
You can download the ZIP file at the bottom of this page: 1.1 in tags – Sonos Wireless HiFi Music Systems
Please note that the “services” subdirectory in this archive is unnecessary.
This version will be available in the MiOS app store in few days.
What’s new in version 1.1:
[ol][li]
UI6/UI7 compatibility improved
[/li]
[li]
IE11 compatibility improved (ok for all UI tabs coded in JavaScript)
[/li]
[li]
UI: style adjusted to UI5 theme
[/li]
[li]
Actions Say, Alert, UpdateGroupMembers and SavePlaybackContext: case ignored for special value “ALL” for the zones parameter
[/li]
[li]
Actions Say and Alert! New possible value “CURRENT” for the parameter “GroupZones” to use the current Sonos group
[/li]
[li]
Workaround for the bug relative to the missing notification when using the Pandora service
[/li]
[li]
New setting to enable/disable reading of the the Sonos main queue
[/li]
[li]
Fix for SavePlaybackContext/RestorePlaybackContext
[/li]
[li]
All plugin settings can now be adjusted in the Settings tab rather than the advanced tab (no reload required)
[/li][/ol]
Can you just install over the older version?
Yes
Lolodomo,
I have downloaded the files in the site for version 1.1.
I would like to update, who knows that error with Favorite radio do not stops ?
where I find instructions to install this files in my vera ?
the first time I installed do not have plugin in app store and my installation was manual.
thanks…
[quote=“Piwtorak, post:4, topic:183007”]Lolodomo,
where I find instructions to install this files in my vera ?[/quote]
The wiki page: Sonos Wireless HiFi Music Systems
The plugin version 1.1 is now submitted for approval in the app store. If Micasaverde/Vera is as quickly as yesterday for the DLNA plugin, this new version should be available for everybody in few hours.
Please note that after the installation finishing by the automatic creation of a new device, you need to clear your WEB browser cache to have a normal behavior including display of discovered Sonos zones.
Version 1.1 has been approved and so is now available in the app store.
I have updated my system manually, uploading the files… and all the scene works with Favorite Radio,
thanks Lolodomo by your great job.
Thanks for the update!
For those like myself who don’t have auto-update turned on and might not know, or have forgotten; now that the update is in the app store, the easy way to update the app is to load the following URL in your browser:
http://vera_ip:3480/data_request?id=update_plugin&Plugin=4226
http://vera_ip:3480/data_request?id=update_plugin&Plugin=4226[/quote]
Thank you for this information.
What will happen if you enable auto update for this plugin ? Will the update start immediately after ?
If it is, a solution would be to enable auto update, wait for the update and finally disable auto update.
UI7,
Sonos controller 1.1 (installed from “app store”)
UPnP 5.0
Seems like TTS does not work. It does not say anything. I tested volume on 60 also.
This was my first attempt with the sonos plug in so far so I might have missed some basic thing.
[quote=“HouseBot, post:12, topic:183007”]UI7,
UPnP 5.0
This was my first attempt with the sonos plug in so far so I might have missed some basic thing.[/quote]
TTS should work.
Please read this topic: http://forum.micasaverde.com/index.php/topic,25689.0.html
Of course, the first point is now irrelevant.
Hello. Hope to post in the right position.
I have Vera Lite 1.5.672 . and Sonos soundbar and Play 1. with firmware 5.1 both.
UPnP Event Proxy installed and running and up to last days the old Sonos app was doing is job.
Yesterday start to give troubles : was now and then OFFLINE (in the APP) but not in my net ( is a fixed ip reserved for the sonos)
Then I was not able to discover or to check status.
So I decide to upgrade to new sonos 1.1 but nothing changed.
Im not able to connect my sonos. Either with assign manually the IP.
All was working well for 6 months!!!
I did not modified my net and I did not played with Vera…because everything was well configurated until yesterday
What shall I do?
Thank you
A new version (1.2) will be released this coming week-end.
Before this release, i am waiting for a feedback for Sonos favorites/Spotify playlists.
Here are the changes you can expect with this coming version:
[ol][li]
Full compatibility with UI7
[/li]
[li]
UI: compatibility with UI6 probably improved
[/li]
[li]
UI: different theme for UI5 and UI7, automatically selected
[/li]
[li]
Fix: IE11 compatibility
[/li]
[li]
Management of Sonos favorites added (UI and scene using SF:title)
[/li]
[li]
New ability to install/uninstall the network patch for UPnP discovery
[/li]
[li]
New setting to enable/disable reading of the the Sonos queue
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
TTS tab: choice added between “Current zone”, “Current group” or “All zones”
[/li]
[li]
TTS tab: add Dutch, German and Portugese as predefined languages
[/li]
[li]
[/li]
[li]
[/li][/ol]
