Hi all. Is it possible in some way to make tasker communicate with the sonos plugin and make tts commands through tasker?
+1
Yes, just use a plugin called “Autovera”. You can then trigger TTS from inside Tasker.
You can find here:
What are you trying to do? Just send text from Tasker to Sonos to say in TTS? If so kos42 is correct, just get AutoVera. I created a profile in Tasker that accepts either an AutoVoice Recognized input or Variable query, then sends the text via AutoVera to MultiString. From there, a scene is executed with luup code sending the text from MultiString to Sonos to say in TTS. Probably a more streamline way to do it but this is one of the first Tasker/Sonos/Vera projects I figured out how to do.
