I have bought SONOS and i really want to integrate it to my vera
I have followed the instructions in the plug in page unfortunately the plug in is not working
after creating the device. It appears it is a normal device nothing special inside only IP in the setting section
(No play stop Mute … buttons)
Did you reload LUA engine (reload button) after creation ? Did you clear your browser cache (Ctrl + F5) ?
Did you create your device using D_Sonos1.xml as device file ? If you did, you should see several tabs including a “Player” tab and “Help” tab.
Can you open the advanced tab of your device and tell us what is the value for device_type and device_file ?
Do you get some messages in the logs relative to a bad starting of the plugin or something else that could help us to determine what you have done wrong ?
I assume you have not uploaded correctly all the required file. In the dashboard windows showing your luup files, can you count how many _Sonos.* files you have ? You should find 10 files.
Basic instructions:
Download the zip file
Extract file to uncompressed in a folder
Upload file to Vera using normal Vera function expect for the icon (.png) and mp3 files.
Use scp to copy the icon and mp3 file to your Vera.
Can someone walk me through installing the mp3 and png files. I see it says to use winscp, but what do I have to put into winscp to connect appropriately? When I use the try to connect to the vera IP, it does not accept the password. How do I connect to upload the files?
