I recently migrated from Lite to Plus. My Sonos plugin fails with Sonos[64] Startup Lua Failed.
I have uninstalled Sonos and UPnP plugins. Reboot. Install UPnP. Reboot. Install Sonos. Get error. Reboot. Still get error.
Running
1.4 plugin
5.0 UPnP Event Proxy
UI7, 1.7.1690, Vera Plus
From Logs:
01 02/24/16 13:23:53.264 luup_require can’t find socket <0x77500520>
01 02/24/16 13:23:53.266 luup_require can’t find socket.http <0x77500520>
01 02/24/16 13:23:53.267 luup_require can’t find ltn12 <0x77500520>
01 02/24/16 13:23:53.268 luup_require require L_Sonos1 failed [string “module(“L_Sonos1”, package.seeall)…”]:9: attempt to index local ‘http’ (a string value) <0x77500520>
02 02/24/16 13:23:53.278 luup_require duplicate socket.url <0x77500520>
02 02/24/16 13:23:53.279 luup_require duplicate socket <0x77500520>
02 02/24/16 13:23:53.280 luup_require duplicate socket.http <0x77500520>
02 02/24/16 13:23:53.283 luup_require duplicate socket <0x77500520>
01 02/24/16 13:23:53.285 luup_require can’t find ssl <0x77500520>
02 02/24/16 13:23:53.285 luup_require duplicate ltn12 <0x77500520>
02 02/24/16 13:23:53.286 luup_require duplicate socket.http <0x77500520>
02 02/24/16 13:23:53.287 luup_require duplicate socket.url <0x77500520>
02 02/24/16 13:23:53.288 luup_require duplicate ltn12 <0x77500520>
50 02/24/16 13:23:53.290 luup_log:66: Sonos: #66 starting up with id <0x77500520>
06 02/24/16 13:23:53.291 Device_Variable::m_szValue_set device: 66 service: urn:micasaverde-com:serviceId:Sonos1 variable: PluginVersion was: 1 .4 now: 1.4 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77500520>
01 02/24/16 13:23:53.388 LuaInterface::CallFunction_Startup-1 device 66 function sonosStartup failed [string “…”]:2089: attempt to call field ‘initialize’ (a nil value) <0x77500520>
01 02/24/16 13:23:53.388 LuImplementation::StartLua running startup code for 66 I_Sonos1.xml failed <0x77500520>
01 02/24/16 13:23:54.101 LuaInterface::CallFunction_Timer-5 function updateProxyVersion failed [string “–…”]:101: attempt to index field ‘sink’ (a nil value) <0x75f00520>
