Unfortunately, this new version seems to have broken the Tunein radio management done by our plugin.
When trying to play a radio (through the plugin), we now get a 402 error.
I will investiguate.
I have found the explanation: a station title is now required in the metadata.
Sorry for that, but I cannot publish a fix immediately because my own version of the plugin is not fully stable (work in progress) as it uses the new UPnP proxy and I have not totally finish this enhancement which is a major enhancement of the plugin. I will disable the use of the proxy stuff in my code as soon as possible in order to be able to commit the fix.
We get UPnP error code 714 when calling SetAVTransportURI which means: “The specified resource has a MIME-type which is not supported by the AVTransport service.”
I don’t know what they have done, maybe simply reduced the buffering size. It probably applies to everything, including Web radio playback (TTS is like a Web radio).
[quote=“lolodomo, post:15, topic:174304”]Firmware 5.2 has been released.It seems to have partially broken the plugin. In particular, playback resume after TTS is no more working.
Anybody noticed that ?[/quote]
That’s weird. This evening, everything is ok ! I don"t know what was happening this morning.
I have done several tests of the plugin with Sonos firmware 5.2 and everything finally looks ok.
